In part works I made a circle with a 87.75" radius. Offset inwards 3.5" for the inner circle.
Through node editing I cut the circle into an arch to fit a 4' x 8' plywood.
I need to put an angle of 45 degrees from the outer radius to the inner. I used draw polyline but cannot get the line to end exactly where I need. The parts are going to be laid together to make the circle when done.
Also when I toolpath I have to cut the outer of one radius and the inner to get the full 3.5" width. Why does it cut the inside of the smaller radius when I select outside? I hopE this is clear enough to get some help.
As always thanks in advance.
David
