Guys,
I was cutting some 3/4" MDF. I was using a 1/2" spiral bit, at 2 ips feed rate, the PC router at 16,000, cutting it two passes. I was cutting small parts out, 12" x 18". This is my first time using a 1/2" bit. I could not complete the first sheet, the bit started to smoke.. and the Y-axis would shudder terrible. Does my little PC not have enough power to spin that bit, is that what is causing the premature dulling of the bit.
I went to a sample bit that I got from Onsrud, a 1/4" Super-O Flute. That left a beautiful edge. I had read that someone had been using one, but couldn't find it. Does anyone know what these run each?
Any suggestions? I normally cut a large amount of MDF, but I use 1/4" spiral bits and many times I use down-spirals to keep the MDF dust packed into the cut, to hold the part. I have wrong a long time with a 1/4" bit.
