Results 1 to 10 of 13
Thread: Speed Confusion...
    Nov 2005
    Because We Can, LLC, Oakland CA
    Default Speed Confusion...
    OK, so, I've got a PRT96 with the standard PC router.
    On another thread about breaking bits, I got some advice to run the RPMs of the router slower and the speed of the shopbot faster. So I was running my PRT96 at 4 ips, taking a 1/4" deep cut into plywood, and it seemed to work just fine. Normally, I was running 1.5 to 1.75 ips before, and being able to double the speed of the 'bot is really, really great.
    However, from reading other threads, I see that 3.4-4 ips is about the 'top end' for a PRT96 in terms of speed. Yet I see other folks posting that they are running 8, even 10 ips, and jogging at 30 (!). Is this because they are running an Alpha, or have a Spindle, or both? Or could I run my PRT96 at those speeds?
    How do you know when you're pushing it too fast?
    Habitat For Bats, Jackson GA
    "How do you know when you're pushing it too fast?"
    Some symptoms...
    Bits break,
    The bot looses its position,
    Bearings in your router wear out fast,
    Poor quality of cuts (tearing and/or chatter)
    router bogging down,
    lots of gantry flex,
    to name a few
    Alphas run faster, as I understand it the controller can keep up and stronger motors are on the Alpha. A spindle also helps, 4HP with lots of torque blows away any Porter Cable.
    I recently started running at 12 ips but my jogs are still at 20. Remember, the faster you go the faster things can go wrong.
    Robert
    Apr 2006
    Hines Wood Designs, Harrison OH
    Dirk has a way to upgrade you PRT to Alpha type speeds. http://www.botrods.com/index.html
    Nov 2005
    Robert, you're cutting @ 12 ips and jogging @ 20 with a normal PRT96 & a Router?
    So it does sound like I could run a lot faster than I have been... hm...
    Feb 2004
    Rogers, Arkansas
    Jeff,
    He's not cutting at that speed with a stock prt! He has an alpha.
    There are several upgrades to a prt that have just become available that can allow your prt to perform faster AND smoother.
    Shopbot has a new 4G upgrade board: www.shopbottools.com
    Botrods (Dirk) makes an upgrade system: www.botrods.com
    and custom cnc has the Ascension system: www.custom-cnc.com
    There has been a fair amount of discussion recently on these upgrades on this forum.
    Nov 2005
    Ken, thanks for the links. Someday in the future I'd like to update the table to run faster, so these will come in handy.
    Today however, I'm still confused about what speeds are sane with my standard PRT96 and PC Router.
    I'd like to cut hardwood plywood at 3.5 to 4 ips. I've run a few jobs this way now, and haven't had any problems (so far). Now, in the past I was running everything at about 1.5 to 1.75 ips, but this was too slow for the compression bits (they were getting too hot and breaking). So I'd like to run at these faster speeds. I see a lot of different folks talking different speeds on the forums here, but they aren't saying in those threads if they are using spindles or Alphas, so I'm confused if the above numbers are too much for my lowly PRT96 to handle. So far so good, but we're in the middle of a big job and I'd really like to not find out the hard way (something important breaking) that we're pushing it too hard...
    , South Jordan Utah
    Jeffery,
    My machine is an Alpha with a 3hp spindle, so high speed and husky feed rates are possible. A stock PRT would probably have to be updated with one of the kits listed above to get feed rates in the 3 to 5-ips range (or higher, depending on a lot of mind-numbing details). A 3-hp Colombo spindle runs very well at full torque in the 12,000 to 18,000 range. It will run considerably slower, but at reduced torque. The standard bearings limit its top speed to 18,000 RPM.
    As discussed before, slow feed rates and high RPMs don't work well together. But, you can change to 1-flute cutters, moderate RPMs and feed rates as fast as the PRT will cut to keep the cutters from frying.
    I didn't mean to confuse, I'm running an Alpha with a 4HP spindle at 12 ips and 20 ips jog.
    Robert
    Jeffrey,
    Have a look at the PRT 4G Upgrade on the ShopBot main site. It will allow you to increase your cutting speeds to around 6 IPS with your PC router & jog @ up to 12 or 14 IPS. It is a really nice upgrade that will totally transform your PRT into a smooth running higher resolution tool. Check it out!
    In the meantime, running the WIndows control software (SB3), your PRT's torque curve falls off very quickly after about 2.5 IPS. You can tweak your ramping settings to cushion starts and stops to reduce the possibility of lost steps when moving at higher speeds. Taking smaller bites (stepdown) will also help to reduce lost steps on a standard PRT while running at higher speeds...but like I said, it sounds like the 4G upgrade is the solution you seek.
    -Brady
    Sep 2004
    The Traditional Rocking Horse Co.,
    Jeffrey
    There has been lots on this, as has been said.
    Look closely at all 3 options highlighted by Ken before you make your decision, and try and find Mikes posts about the 4G
    All 3 solutions appear to have advantages and disadvantges, but you do have a choice of alternatives.
    Or make your own
    ...........Mike
  1. Feed / Speed / Chipload confusion
    By sagreen83 in forum Archives2007
    Last Post: 12-04-2007, 08:32 PM
  2. Indexer confusion??
    By myxpykalix in forum Archives2007
    Last Post: 04-02-2007, 01:27 PM
  3. Design confusion
    Last Post: 03-09-2007, 03:03 PM
  4. Partwizard confusion
    By myxpykalix in forum Archives2006
    Last Post: 10-16-2006, 10:13 AM
  5. Offset confusion...
    By harryball in forum Archives2006
    Last Post: 09-06-2006, 11:50 AM
