Results 1 to 10 of 16
Thread: My New Milwaukee 5625 Router! (yeah,... BABY!!!)
    Feb 2004
    Default My New Milwaukee 5625 Router! (yeah,... BABY!!!)
    I know that there have already been other threads about this router, but I'm too lazy to search for and find the ones that convinced me to buy this Milwaukee when my old Porter-Cable 75182 recently (and finally) bit the dust with bearings and switch issues. My 75182 was a damn good router and didn't owe me a dime, and if it wasn't for some reviews I'd seen in here about the Milwaukee, I'd have purchased another one. But meanwhile...
    The first thing that struck me about the Milwaukee is how much quieter it is that the P-C. I can actually hear myself think now and even talk on my shop phone without having to take it outside. It may not be as quiet as a spindle, but I don't have $5,000.00 for a spindle and nor do I need one for my particular applications.
    The 2nd thing that I liked a lot was the variable speed function. It's more user friendly than the P-C and gives you greater control as it is "dialed" and not "switched". Sweet!
    The 3rd thing was the ease of install. It fit perfectly into the carriage for me with no modifications necessary to speak of other than a cable clip and a short screw to hold the power cord out of the way where it comes out of the motor housing.
    The 4th thing is that it has a 5 year warranty! Wow!
    For anyone interested, here's where I found the best deal:
    http://www.tools-plus.com/mlw5625-20.html
    MARK HOLM (Unregistered Guest) Guest
    Are you saying that the new Milwaukee fit into the same mounting sleve that the PC was in?
    Oct 2001
    Mark Tucker's SB is from the early days of a U-plate and 2 hose-clamps over the top. pic Paco mentioned somewhere else that the Milwaukee is slightly smaller than the PC and that he put a sheet of something in the later sleeve to make up the difference.
    Lenox High School, Lenox MA
    The noise level of routers is obviously a big issue when you run a router a long time. Is there a source that rates routers by noise level as well as other considerations? I haven't been able to find one.
    Feb 2004
    I can't find one either, Phil, but take my word, The Milwaukee is at least 25% quiter than the P-C, and that made all the difference to me. However, it STILL depends on what you are cutting and perhaps how fast you're cutting it. I rout a lot of HDU foam and can set the variable speed to it's lowest (10,000 rpm) on the Milwaukee and I can barely hear it. This evening though, I had to cut up a sheet of 1/8" aluminum. I cranked up the speed to about 18,000 rpm and had at it. The Milwaukee sliced through it like a champ and with no complaints, but it naturally puts out higher decibles as the variable speed is increased. The REAL noise, however, came from the cutter slicing through the aluminum @ 1.25ips.
    Long story short...I put in my ear plugs! :-)
    , Pittsburgh PA
    This is part of a post I did not too long ago:
    The installation required removal of the adjustment screw and the addition of four 2 5/8" x 13" strips of standard .078 flashing around the router for mounting. The process took about 30 min and it was well worth it. Noise level is significantly lower.
    Bill
    marshawk Guest
    The brushes for it are available at http://www.toolpartsdirect.com. It took about 4 weeks to get them, so you may want to order them now and have them on hand.
    One of the things that I like about the PC routers is that they are easy to maintain. It takes no more than 5 minutes to change the brushes with the router still installed on the 'Bot. It looks as if changing them on the MW will take a little more effort...but still worth doing myself rather than taking it to the local power tool repair place.
    Cheers!
    Chip
    May 2004
    FoamFly.com, Ypsilanti MI
    I just got one of the Milwaukee routers, and was surprised to find that is it too big to fit in my Alpha mounting bracket. The bracket included a black plastic insert that narrows the opening to 3.5" with the insert. Without the insert, the bare aluminum mount is too large to hold the Milwaukee.
    Do I have a non-standard mount or something? The plastic insert is about 1/2" thick all the way around. What does the rest of the world have? In the pictures it looks significantly thinner.
    -Dan
    P.S. I never had a Porter Cable, I'm replacing a Makita, so I have nothing to compare it to.
    Jul 2004
    Valcourt, Québec, Canada
    Hi Dan!
    My black insert is about 1/8" wall thick. It was for the 7518 PC originaly.
    Check with SB for the PC insert.
    Maybe you could get away with some kind of flexible plastic such as 1/8" thick UHMW and make yourself an insert...
    Novato CA
    The Milwaukee is not the same dia. as the PC so you need to make a new insert for the Milwaukee to fit in the bracket. I wraped a sheet of .125" thick neoprean and 26 gage (I think) aluminium to make up the difference. Hope this helps.
  1. Milwaukee 5625 Router
    By cncworld in forum Archives2008
    Last Post: 09-27-2008, 08:02 PM
  2. Milwaukee Router 5625 Collet Picture
    By rustnrot in forum Archives2007
    Last Post: 08-22-2007, 12:33 PM
  3. Replies: 4
    Last Post: 02-26-2007, 05:32 PM
  4. Replies: 16
    Last Post: 02-07-2007, 06:44 PM
  5. Milwaukee 5625
    By jbworden in forum Archives2006
    Last Post: 07-14-2006, 06:39 PM
