I probed a small hand carving and have a sbp. file that the shopbot control software will simulate. But it would not load into aspire. I reprobed the carving to save as a DXF file, but it would not load into aspire either. I contacted Frank at Shopbot support,, he told me to run the SBP file through the converter in Shopbot3,, and then it should load.
I have had no luck at all,,, when I run the SBP file through the converter, the picture on the screen looks like a bar code,,
Can anyone help ?
Thank you on advance, Charles
