Has anybody tried this? For dust collection I've built a duct out of light wall 1" X 2" tube and bolted it to a bracket which I've attached to the aluminum bracket that holds the guide wheels on the back of the Z frame. It then travels down and under the Z frame and attached to the end is a small fan shroud which I found in my travels. The fan shroud surrounds the router bit. The whole unit travels up and down with the router as it is attached to the same carriage. The duct work is adjustable in height by a group of set screws on the Z carriage bracket which it can slide through.The top of the ductwork adapts to a shop vac hose which travels its usual route off the table. The unit weighs a bit but I'm only using a 1 1/2 HP PC so I figure the Z motor can handle lifting it up and down.
