joecnc...
It is not neccessary to add an 1/8 plate to the bottom, unless you want to. You do need to enter the proper thickness for whatever material you use.
Joe J...
If you are asking about my corner jig, the aluminum block is screwed to a plexi plate, which in the video is held by vacuum. I have tried just setting loose, but have not had the best luck with that method.
Gary
