I bought the Spindle Control Board from ShopBot for my PRS Standard with Yaskawa VFD. Installation went smoothly and everything works great -- until I start the spindle. Then the Spindle RPM Tool (TR command) freezes up so badly that it can't even be terminated with the task manager.
The problem only happens if I use the RPM Tool and the spindle at the same time (including a TR command embedded in a cutting file). Unfortunately, this pretty much defeats the purpose of the investment.
I called ShopBot tech support and spoke with two different people, and so far we haven't found a solution. Both asked if the ground was loose in the VFD (it wasn't). They also felt that the problem was due to RF interference from the VFD (or something else) and encouraged me to try to mount the spindle control board as far from the VFD as possible (which I find surprising, since the installation guide shows it being mounted inside the VFD). I've also tried an alternate computer and achieved the same results.
So far, with a USB extension and an alternate wire (shielded), I've tried a distance of 10' from everything (VFD, computer, Bot, etc.) and still seen no signs of improvement.
I'm wonderig if anyone else has something new I can try.
