Results 1 to 10 of 18
Thread: Texture surface on Cement
    Oct 2006
    WildWood Mfg.., Ulm Montana
    Default Texture surface on Cement
    Couple of questions, if someone has the time to answer.
    I am putting a bid in on a sign that will be out doors. Right now there are two cement panels 6X15' with some metal letters and graphics on posts.
    They want this to look like Sandstone and with a new name and some different graphics. I called Coastal Enterprises on the precision Board for the letters and coated with PB resin to harden the letters.
    Also looked at their TSF-45 Texture, to place on the cement to get the texture of sandstone. Then I thought I would use sponge and paint to give the texture some color.
    The letters would be placed over metal pegs drilled into the slab and held in place with silicon or such.
    This sign sits on the ground, in the sun, snow and hail. As well they have lots of vandalism and most of the damage they see is from gun shots.
    I talked with them, and they were quoted $12,000 to redo the sign using metal. They can not afford that. I figured I should be able to do the texturing and 64, 6-8" letters for considerably less than that. And by making another 20 back up letters they could be replaced when damage got extensive.
    What experience have you had with TSF-45 texturing? Any idea on aprox. How many square feet the texturing will cover? Any experience with it sticking to cement, after the cement has been sealed? What would you suggest to hold the letters on, knowing that many of them will eventually have to be removed and replaced?
    How to make the sign so bullets ricochet directly back at the shooter?
    Any help is appreciated.
    Butch
    Aug 2005
    Signgraphics, El Cajon CA
    That sounds good, but I would only make 2 or 3 extra letters to keep for samples when they need some more. I would silicone them on if they are that small. If they do get damaged, it's easy to bondo up and repaint. Keep good records of exact texture and colors used.
    This is a great ongoing customer.
    Norman, Ok
    Butch,
    Here's my 2 cents,
    We've made several concrete surfaced signs. Looking back I'd have to say using a hopper gun is the fastest and technically safest way to go.
    The pockets are made to inset letters.
    I started with a structure of treated 2"X4"s and covered with OSB. Trowel on a Drivit like concrete, www.demandproducts.com and spray the final coat with cheepit deepie hopper gun.
    You can sand the surface to make any testure desired within four hours.
    My first attempts were made with Extira. Much too heavy but I wanted to do some carving on the background and it did well for that. Spray coats of concrete. The final surface can be quickly sanded smooth.
    Norman, Ok
    Butch,
    Another thougt:
    You could make the whole sign with Preciaion board, harden it off with their epoxy or styro spray, (rolled on) and top coat.
    Is this a double sided sign and what grqphics will be included?
    Feb 2004
    I think Joe is on the right track with the spray-on simulated concrete. Nothing, however, is gonna hold up to a bunch of vandals with shot guns. I would think about 3/4" MDO as the background substrate with the sprayed-on finish and the MDO mounted a few inches off the ground on pressure treated post. You could then come back with say, cut out letters out of HDU, stud-mounted, and I wouldn't worry about a hardener. A sign like that could be repaired easily enough. 6' x 15'? I think you're gonna have seams, no matter what you do. Just my 2 cents.
    Norman, Ok
    Mark,
    There's perforated mesh, which comes in rolls, to bridge gaps and streghten corners. Once applied there's not much worry about cracks. For example, Taco Bell and structures with cretatious surfaces seldom suffer from fisures.
    My best letters, for this process, is Extira since it accepts bolts and many kinds of adhesives. HDU's don't do well with metal studs and is more deliclate.
    Feb 2004
    Joe, agreed about HDU and studs. I don't use Extira because I'm too old to lift up a sheet of that stuff! ;-)
    We don't have enough info to help him much at this point anyway. The customer evidently has a budget or would have sprung for a bullet proof solid steel sign, lol! And at 6' x 15', I'm trying to think of something that could be assembled at the job site. I'm just a one-man shop, so I always think that way! :-)
    Norman, Ok
    Mark,
    Me too with the weight of Extira. I use it only for letters. I can't imagine not having it in our shop. The only problem is getting the 1" stock out of the truck.
    I should get paid for all my free advertising for Extira. That and Precision Board are the two most used sheet materials used around the shop.
    Oct 2006
    That helps.
    I always appreciate the help in this forum. I'm stepping out of my area of comfort with this one, but the help from here helps taking on new challanges.
    The sign is two sided. I believe they are going to pick up the cement slabs and move them to the new site. He wants the images to remain in metal as idiots like to shoot at the buffalo images. Thus I dropped the idea of a 2.5D buffalo carving done in foam board. But the lettering gets too expensive to do in metal(thus the $12,000 bid), so he figured if we keep a few extra letters in the D and O's we could replace them as needed.
    I am a little concerned about texturing the cement and getting a good bond but sounds like it will work. I had not thought of spraying the texture on, good idea!
    If they decide to go this route with me, I will post some pictures, before it gets shot up. What ever happened to target shooting empty beer cans?
    One thing about it, it should be a yearly maintance job, so that is good I guess.
    Thanks again for the help.
    Oct 2006
    Graphics
    Forgot this.
    They want two or three buffalo done in metal outline, jumping off a cliff. They would like that on both sides. But I am working on them to place the buffalo on the top and can be seen from both sides.
    No other graphics, just the lettering.
    Butch
  1. Improving cut path efficiency of texture on curved surface?
    By acemeyers in forum Designing and Creating the sbp cutting file
    Last Post: 02-05-2016, 01:08 PM
  2. contact cement
    By gene in forum ShopBotter Message Board
    Last Post: 02-13-2015, 02:47 PM
  3. Spray Canister Contact Cement
    By john_l in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 05-22-2010, 02:41 PM
  4. Foam safe contact cement
    By john_hartman in forum ShopBotter Message Board
    Last Post: 08-13-2009, 09:17 PM
  5. Rubber cement masking
    By ilsaarin in forum Sign Making
    Last Post: 07-17-2009, 03:54 PM
