I have a sign that I will be routing out on both sides, it is 1.25" thick, it will be V-Carved and End Mill cuts will be used.
What is the best way to hang signs made of Sign Foam to a swinging bracket?
That is.... should I use screws, lag bolts, or some form of epoxy to attach to the desired hanging points where the chain is attached to?
Any and all ideas are welcome.
- Thanks, Sam Errett
