Results 1 to 10 of 11
Thread: Running a file multiple times
    Aug 2005
    Oakwood GA
    Default Running a file multiple times
    I know the info has been posted several time but I can't find it using the search. I must not be using the right key words. I need to run a cut file 26 times. What I'd like to do is have box pop-up, ask me for the file to run, turn the spindle on, cut the file, move home or to a safe area, ask me if I want to run the file again or quit then when I choose quit turn the spindle off.
    If you can point me to a previous thread or give me some info I would greatly appreicate it.
    Andy B.
    Habitat For Bats, Jackson GA
    Andy,
    Probably not the best form but here is a master file that allows me to choose which cut file and speed to use, then cuts and moves the gantry out of the way for a board change and lets me continue, enjoy.
    'This files calls the side files and repeats for production purposes.
    'The spindle is turned on and left on for the duration so it will auto start when each file is called
    'You should have a 3/8 roughing bit and Zzero to TOP of material.
    PAUSE
    SA
    SO,1,1 'Turning spindle ON for first time
    PAUSE,2
    PRINT "Run File Cutting Options"
    PRINT "1) E2-L Load Position 1"
    PRINT "2) E2-R Load Position 1"
    PRINT "3) E3-L+R Load Position 1"
    PRINT "4) E4_E2-L Load Position 1"
    PRINT "5) E4_E2-R Load Position 1"
    PRINT "6) E2_L+R Postion 1 & 2"
    PRINT "7) E4_E2-L+R Load Postion 1 & 2"
    PRINT "9) QUIT and EXIT"
    PRINT
    PRINT "Enter Cut Speed - Decimal values ok i.e. 4.5 "
    PRINT "2) 2-ips 6K RPM for knotty boards"
    PRINT "3) 3-ips 7K RPM board with some knots"
    PRINT "4) 4-ips 9K RPM very small knots clear board"
    PRINT "5) 5-ips 10k RPM very good board "
    PRINT "6) 6-ips 12k RPM perfect board no knots"
    PRINT "REMEMBER TO SET RPMS AS REQUIRED"
    PRINT
    REPEAT:
    'Request which side file to run
    INPUT "Select File Cutting Option from menu -" &cut_side
    IF &cut_side = 9 THEN GOTO DONE
    'Now request the cut rate, slower cuts are for knotty boards, fast cuts are for good clean boards.
    INPUT "Select Speed of Cut from menu -" &cut_speed
    IF &cut_speed = 9 THEN GOTO DONE
    IF &cut_speed > 7 THEN GOTO CRAZY
    SO,1,1 'Turning spindle back ON
    Aug 2005
    Oakwood GA
    Thanks Robert. That's a start. I have two jobs coming up that I will have to cut 25+ sheets of the same parts. The time to start the spindle is slowing me down. I'd like to get it down to starting the file, unloading the parts, blow the table off, throw another sheet on and start cutting again.
    Andy B.
    cnc routing, portland or
    I have a couple of lines you put in that parks the router where you want it and you touch the zzero plate to start the toolpath again. when I get to work I will post it. the spindle keeps running so you don't have to start anything again.
    Oct 2000
    Atlanta GA
    The fastest and easiest way to repeat a file unlimited times is to put the following at the end of the file:
    PAUSE
    GOTO BEGIN
    at the beginning of the file, after the SO 1,1 which turns the router on but before any movement commands, insert the label:
    BEGIN:
    That's it. The spindle runs the whole time and the file repeats itself when you press Enter. When you are done you press Escape instead of Enter which ends the file and turns the spindle off.
    For a more elegant solution if the file is likely to be run again I use something like this added to the end of the file:
    C4 'my shortcut to park the router out of the way
    input:
    INPUT "What next? [R]epeat, re[Z]ero, [B]it change, 0 to end" &next
    IF &next=0 THEN END
    IF &next=R THEN GOTO begin 'repeats file
    IF &next=Z THEN GOTO rezero 'goes to a z zero subroutine
    IF &next=B THEN GOTO changebit 'goes to a bit changing subroutine
    GOTO input 'any non-valid entry will repeat the question
    There are unlimited variations possible. For a safer version of the first method use:
    INPUT "1 to repeat, 0 to end" &next
    IF &next=1 then GOTO begin
    that way you have to make a deliberate entry instead of just pressing Enter which could be done accidently. Any input other than "1" ends the file.
    I could go on...
    here is the info this uses the input on to start the file again so I just tou8ch the zero plate to the machine and off it goes again
    REPEAT: 'Place the repeat where you want the file to repeat from.
    'Body of part file
    WAITHERE:
    &TEST=%(51) 'Testing the condition of the input switch. %51 is input 1, %52 is 2, %53 is 3, etc.
    IF &TEST=1 THEN GOTO REPEAT
    PAUSE .3
    GOTO WAITHERE
    Sep 2005
    Mountain View Wood Works, Troy VA
    Rather than using the Zzero plate, you could wire up a SPST pushbutton to one of the other inputs and change the %(51) to the input the button is wired up to. Then you would have a "GO" button that is not the Zzero plate. If I were doing it, I would put two push buttons in series and mount them so I would use both hands to push them. No chance of hitting the button and causing the machine to move while you were still working. All above work good, just think about safety!
    Take care
    Feb 2006
    , Canyon Lake TX
    This won't work for full sheets but rather cutting multiple parts from a single sheet.
    You can call up cut files in a cut file, like this.....
    'For ShopBot Control: SB3 Alpha
    'Set router RPM to 13000
    PAUSE
    'Turning router ON
    SO,1,1
    PAUSE,2
    SA
    M2,1.25,1.9375
    FP, RufBottomStrip01a.sbp,,,,,2
    M2,3.75,10.9375
    M2,1.25,19.9375
    M2,3.75,28.9375
    M2,1.25,37.9375
    'Turning router OFF
    SO,1,0
    I thought of using a switch but I don't do it often enough. the plate is pretty good safty since it takes some effort to use it.
    Aug 2005
    Oakwood GA
    Thanks for all the suggestions.
    David,
    I like your safe version. Thanks for another great tip. I'll work on a better solution when I have time.
    Andy B.
  1. Times running gout
    By mezalick in forum Camp ShopBots/User Groups/Training Classes
    Last Post: 12-27-2016, 04:58 AM
  2. Running multiple tool paths on one job (V-Carve)
    By Mr.Mediocre in forum ShopBot Desktop
    Last Post: 05-06-2016, 07:21 PM
  3. Cutting same part multiple times
    By bud_wilson in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-05-2009, 11:11 AM
  4. Optimizing file size for shorter cut times?
    By myxpykalix in forum Archives2007
    Last Post: 12-22-2007, 12:31 PM
  5. Replies: 21
    Last Post: 08-03-2004, 03:50 PM
