Thread: Y axis prox switch and end stops
    Jun 2008
    , Chapel Hill NC
    Default Y axis prox switch and end stops
    I am setting the prox switches for my shopbot . X axis went well , but I have questions about the y axis. The table is centered between x- rails. The end stop to the right of the y motor stops the bot at about 3/4" past the edge of the table. I had to set the prox switch inside the stop so I now have 1/2" clearance. That is with the stop pushed as far right as it can go. On the other three sides I have a clearance of 2". I am concerned that with a large cutter head I will not have proper clearance.
    Also are proximity switches used to set a home position , are there any suggestions of other methods?
    Mar 2008
    Tulsa Oklahoma
    Greg it sounds like you have thought it out, I put my limit switches just outside the cutting envelope for the same reason.
    Another good way to find home is to "center in a hole". That routine is in the C:\SbParts directory named "S_Center_inHole.sbp". That depends on you creating a small hole at the home position in the spoilboard. It also requires you have a probe, or a superzero to make contact with. (look up the superzero devices in the forum). You can also set Z from the bottom of the hole.
    I am working on a simple method of setting zero using a shoulder bolt. So I have written a routine similar to what comes with the shopbot I call "center on bolt". I will be posting more on this technique later, when I have a list of parts written up and have done a lot of repeatability testing.
    Other common methods are edge finding, and lasers centered manually on zero. Look up lasers elsewhere on this forum.
    When I start my bot, I always use C1 to find the "home" prox switches. Then if I have a part mounted on a vacuum fixture I will often use the lasers, or "center on bolt" to set the zero relative to the fixture, or the part.
    And then if I am cutting an oddball part that is just clamped down to the table, I intentionally put it on a part of the bot that doesn't get used as often, then the wear and tear on the rack gears gets a little more evenly distributed.
    Hope those suggestions give you some ideas to get going with.
    D
  1. Prox Switch Issue
    By Magick in forum ShopBotter Message Board
    Last Post: 11-04-2015, 08:06 AM
  2. Y axis end stops and prox switches
    By dcribbs in forum PRS Assembly
    Last Post: 09-19-2014, 03:22 PM
  3. Y axis Prox switch light never goes out.
    By scottbot in forum Archives2008
    Last Post: 05-18-2008, 07:34 PM
  4. Z Prox. Switch
    By propellers in forum Archives2007
    Last Post: 08-26-2007, 07:02 PM
  5. Troubleshooting Prox Switch
    By robinsoncr@naxs.net in forum Archives2003
    Last Post: 08-19-2003, 01:04 AM
