As i'm sitting here waiting to play santa, I was mulling some ideas over for wainsoting. I have some questions that maybe you experienced millworkers might be able to answer.
Looking at the picture here what i see are several "elements".
1) You have the rails and stiles that make up the frame and the raised panel in the center.
2)You have the fluted 1/4 columns with the plinth blocks on top and bottom.
3) you have the dentil molding along with the chair rail.
Rather than make all those components I was wondering if the shopbot or specific software could design 2 to 3 panel sections on a solid piece of mdf and just attach it as a single 8' piece?
1)My thinking was (since i've never made wainscoting) that you would start with a solid piece of 3/4" mdf
2)Where you see the fluted columns the width might be 4" and you leave that thickness at 3/4".
3)Where you see the rails and stiles, and raised panel that could be rough cut down to 1/2" thickness.
4) Where you see the raised panel the "raised panel "grooves" could be milled down to 1/4" thickness.
I see several different toolpaths and bits here.
1) planing bit to get it to the correct thicknesses in the rough toolpass
2)corebox bit to make the flutes (a flat fluted panel might be easier to create) and the design on the plinth blocks
3) a Vbit to create the fake raised panel.
Has anyone made anything like this (or a fake raised panel door) design? Am I on the right track here? Are there things i haven't considered yet? Do you have any suggestions, tips, tutorials, files, anything that might get me in the right direction? Thanks!
