Thread: Cutting depth Speeds (the simple way)
    Feb 2007
    Default Cutting depth Speeds (the simple way)
    Poted this once before but I don't see it showing up in list.
    I use a PRT standard and ouput .sbp with VcarvePro. I mostly cut 1/2 and 3/4 Melamine and 1/2 and 3/4 MDF. I use screws for hold down. I have never changed the VcarvePro default tool settings and think it's time to do so. It takes about 6 passes to get through the 3/4 Melamine.
    My current settings for 1/4 end mill (down spiral) are Pass Depth .125, Stepover .1, speed 12000, feed rt 100, Plunge rt 30.
    What should I change settings to to be more suited for my use?
    Apr 2006
    Hines Wood Designs, Harrison OH
    Do a test with multiple speeds at full depth. You'll be surprised at what it can handle. Best way to test is make 10-14 36in. lines in V-carve. On mine I cut them in one pass at full depth, but changed the feed/rpm on each one. I went from 4 ips up. I cut 2 lines using the same feed rate but changed the rpm so that I could get the right combination. It helps out a lot, you can really see how finding the right mixture will reduce chatter and make a smoother and quicker cut. Use the Chip Load Calculator to get a starting point for feed rate and rpm speeds.
    Jun 2007
    Russell Ontario
    We cut using a PRT standard, 1/4 compression bit 10 k RPM on a PC router, 3/8" per pass at 1.8 IPS. It's quiet and we get good results. A small amount of bit deflection.
  1. Feeds, speeds, and cut depth question
    By Simon Anderson in forum ShopBot Control Software v3
    Last Post: 12-13-2015, 06:35 PM
  2. Simple ? about test depth
    By gsartor_1999 in forum ShopBotter Message Board
    Last Post: 02-29-2012, 07:03 PM
  3. HDU cutting depth....
    By gamisano in forum Archives2007
    Last Post: 02-05-2007, 04:05 PM
  4. Feeds, Speeds and Depth of cut.
    By jthelen in forum Archives2005
    Last Post: 08-31-2005, 10:53 PM
  5. Cutting Depth
    By Wgoff@capital.net in forum Archives-2002
    Last Post: 07-10-2002, 12:07 AM
