Thread: Question about pocket cuts
    Aug 2005
    Signgraphics, El Cajon CA
    Default Question about pocket cuts
    I do a lot of pocket cuts with a 1/8" or 1/4" end mill. I cut a lot of HDU foam signs. I cut at 4 ips. The little problem I'm having is the cut leaves some different depth cut marks that are sometimes difficult to sand out because its close to the raised letters and scrolls. I cut with the raster so it is at least horizonal.
    Is there something else I could do to make a better, smoother background? Sometimes I put a V Carve woodsie texture in it.
    Apr 2007
    Marquette, MI
    John..
    Others have had the same problem..see this post:
    http://www.talkshopbot.com/forum/mes...tml?1198106345
    Even tho your sign foam cutting may not develop much side load on the bit, you may be having some of the same problems. We solved ours with a tuneup up of all the Z motion components.
    http://www.talkshopbot.com/forum/mes...tml?1198025229
    Hope some of this helps.
    Gary
    Mar 2005
    Cabinets Plus of Augusta, Hephzibah Ga 30815
    Fred at centurion sells a 1/4 " compression bit that has a bottom set up for dados, it does very good and is under 20.00 ... i use it for cutting cab ends with dados and cutting out the whole piece so i dont have a bit change
  1. Pocket toolpath cuts are undersized
    By John Murray in forum Troubleshooting
    Last Post: 06-30-2016, 09:26 AM
  2. Need help with clean bottom pocket cuts
    By mmak2916 in forum Techniques for Cutting, Drilling, Machining
    Last Post: 03-15-2015, 08:26 AM
  3. pocket cuts
    By john_hartman in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 07-01-2011, 07:59 AM
  4. Pocket Question
    By signtist in forum Archives2008
    Last Post: 08-21-2008, 11:35 PM
  5. A Question About V-Bits and Corner Cuts
    By jemelby in forum Archives 2004
    Last Post: 12-20-2004, 07:22 PM
