I'm confused about how i can run flutes down and around a column like a traditional column straight down. The "forney fluter" looks like it will only do flutes on flat pieces. Under the indexer I tick "turn traditional flutes, spirals or rings"
It asks about "number of times pattern wraps around blank" ect so i don't think that will work either. My interpretation of that is like if you are making a spiral. Thats not what i want in this case.
Seems to me you need to take the diameter of the column and the diameter of the bit and the distance between each flute and figure out how many flutes will equally go around column. I may be getting hung up on terminology within these tools as to why i don't understand. Any clues guys? thanks
