William,
Yes you can, but with a couple of caviats. You can glue veneer, melamine, laminate, metal, or other substrates to it using Urea, contact cement, 5 minute epoxy, Gorilla glue etc. It's porousity allows an excellent bond with almost anything, but, whatever you do to one side, you must do to the other to prevent assymetrical shrink and pull. You do not have to use the same thickness, but whatever you apply to one side you must replicate on the other within a reasonable time frame, say, the same day. Also, you have to remember that this product is a structural foam, and although it has great characteristics, it has virtually no "grip strength" for hardware such as screws, bushings, etc, unless you replace a small square of the product with hardwood, bonded in place with a good 5 minute epoxy or similar product. We do this often, however, we don't use any wood screws at all, just threaded inserts of different size, pitch and lengths:
http://www.aircraftfast.com/inserts.htm
(Sandwich Panel honeycomb inserts on that page)
Thin melamine applied on the reverse side first then your veneer applied on the obverse side would do just fine. Klegecell has great resiliency. You can take a piece of 1/2" and bend it nearly in half before it snaps. But, because of that, it might be advisable to make sure that your piece of Klegecell is supported as much as possible underneath if you are intending to add wings or heavy wood structures on the perimeter of the table, unless you are anchoring those additional pieces on some other structure of the base other than the Klegicell.
