This is a 4”x4.25” block that has a max cut depth of 2 3/8”. It is a combo of 2d and 3d cut files all rolled into one with v carve pro. It takes 4 minutes to cut with a ½” bit and another 30 seconds for the v bit to make the angled cut in front. I have the toolpath also level all the blocks to the same height. I may do 20 or so of these at a time.
I made a nice vacuum puck just for these and I go and zero the bit and the first problem creeps up I run out of z room. I solve that issue to only have the block come loose and fly off.
So I used to old fashioned method and clamp the block. In the long run this is better as it is very easy to place the block remove it for another one and be able to place it back again for the second tool cut.
