Results 1 to 5 of 5
Thread: Angled dados?
    Oct 2006
    Default Angled dados?
    Can the shop bot do this?
    Basically 3/4 inch wide and 1/2 deep at on side and 1/4 at the shallow side for the whole groove.
    Currently use a dado blade in a tablesaw tilted to what angle we need.
    Thanks!!
    , South Jordan Utah
    You'll probably have to tilt the material. All axes on my machine are perpendicular to each other with no easy tilt adjustments.
    Sep 2004
    The Traditional Rocking Horse Co.,
    As (the other) Mike says.
    Make a jig that holds your material at the desired angle (18º) , then cut normally.
    .......Mike
    Oct 2006
    Thanks guys!
    Feb 2006
    But remember that the jig will compress the measurements perpendicular to the axis you rotate on. What I mean is - if you are rotating along the y-axis, then you'll be compressing measurements on the x-axis. You'll need to do some precise measurements (probably by trial and error) to get it right.
  1. blind dados
    By 2006prt in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 05-31-2012, 09:38 PM
  2. angled plane for guitar
    By brian in forum ArtCAM
    Last Post: 04-12-2012, 06:47 PM
  3. pockets/dados
    By john_hartman in forum Cabinetry and eCabinet/ShopBot Link
    Last Post: 03-23-2012, 12:56 PM
  4. Inconsistant dados
    By andre in forum Archives2007
    Last Post: 07-11-2007, 11:06 PM
  5. Query - Setting up 2 sided, angled work
    By johnm in forum Archives2007
    Last Post: 04-29-2007, 10:26 PM
