John,
On a project this size, Z-level roughing is a necessity. There's just too much force on the long cutter to forego the roughing pass. At 1st glance a roughing pass seems like a waste of time...when in reality, if the bit could take the force without serious deflection or breakage, you would have to run it at a very slow rate...and the cutting would actually take longer & the finish quality would suffer. You can get away without roughing on smaller & shallow reliefs. Most of the time roughing only takes minutes & saves a lot of time.
Scanning...yes...This is a essentially a digitizing service that I offer to those who cannot afford a professional laser setup. This is a unit that I designed around industrial laser sensors and it is the result of over a year of R&D. The hardware is not for sale or available. The service however is. I've scanned everything from a giant ice cream cone to musical instruments and customers send me things from all around the world. Many of my customers have Picza, NextEngine and even Scantech units, but need a higher resolution relief, something that their equipment cannot do. I really don't want to get into the CMM equipment business, but I do offer high resolution scanning at a very affordable rate. If you need scanning you can forward me pictures of your model for a quote. At the moment I am putting together a dedicated laser rotary scanner, which will scan 5-sides of a part in one go. This will be ideal for those who need models for the indexer, or multi-sided parts.
Don't throw away your touch probe! You can still scan 2D patterns and shapes with it!
I used the SB probe for years & it is an excellent way to get into digitizing on a shoestring. I started getting more digitizing work than the SB could handle (time/speed) so that's when I began researching lasers.
PS- Here's a pic of the ice cream cone. It was about 6" in Z.
