I found these on the web, any pros or cons or others you might go with? Second link is one in use.
http://www.apinex.com/ret2/cr60an.html
http://www.youtube.com/watch?v=Oc-9gTFj-y4
The laser is nice, but I want the controller! I couldn't make out what he called it. Does anyone have a link?
g.
here is the link to that controller:
contourdesign.com
Try this link for the controller...
http://www.amazon.com/Contour-Design.../ref=de_a_smtd
I debated on getting one of the controllers. but decided a little keyboard would be more practical.
but I have been interested in the laser I can't find one in the US so far.
Thanks for the link.
Steve, I've got one of these:
http://www.lasercenteredgefinder.com/
It works very well! I use the Mini version with a 1/4" shank.
g.
I have been using a shuttle pro for about 1 1/2 years, one of the best add on's I've done. Extended with 32' of usb I can operate my machines from either end of the table or walk around it.
The latest add on, which I took to Ed's Camp is the optical viewer. Rather than a laser this is a simple usb camera with plug in which adds rotational cross hairs, cutter dia, axis position plus more.
Just another option.
well that looks interesting. what plug in are you using. my question is using the superzero I know if something happens I can get exactly back to zero every time. I wonder if using the laser or camera would let you do that? since your eyeballing it?
Steve this particular plug in is running under mach but there's no reason you can't adapt it to SB3 as well.
As far as getting back to zero, I run homing switches, start of each day and/or if something happens one click and the machine reference's all home to the switches, not a problem.
Any more info on the optical viewer?
