Greets. Some of you know that I'm trying to noodle out the right vacuum table system for myself after 7 years without one. I was close to buying 2 new Fein Turbo's for $750.00 (with free shipping), but lawwd have mercy! I can get 4 Imperial VBTST6460VM vac motors for $234.00 less and have, as everyone says, superior performance and that's my plans as of today, 4 of them suckers!
If interested, please click on the following link and study my plans for a minute:
[IMG]http://i50.photobucket.com/albums/f3...cPlansSBMB.jpg[/IMG]
You can see that I want a 4 zone table with 4 motors, but I also want some flexibility as to how I use them (the motors). I don't want to reinvent the wheel and I'm trying to stay away from extensive and expensive manifold work and keep things as simple as possible.
Everything you see is located under the Bot, meaning the motors and the PVC plumbing. The motor boxes are to sit directly on the floor connected straight up into 2" PVC 4-way Tees as shown, which elbow off into 4 PVC ball valves, "A,B,C & D" and also connect to the plenum vacuum holes . My thoughts are to be able to zone off these motors easily and effectively as I need to and as the case may be. In this particular imaginary case, let's say that I am cutting through some small tough parts and only need 'zone 1' for space but need extra vacuum power to hold everything in place in that zone. I am showing in my plan ball valves B & C closed and 'motor 2' will not be turned on. I will run motors 1, 3 & 4, but I would plug their plenum vacuum holes (3&4), with simple (and cheap), 'pressure test plugs' (signified by the blue dots in the top of the 4-way tees), so as to direct their vacuum power to zone 1. 'Motor 2 Zone 2' won't need a plug as it would be closed off and not running.
Does this make any sense? Am I on the right path with this? If I was cutting through in all 4 zones out of a 4x8 sheet I would open all the valves and turn on all 4 motors. In my mind I see all the flexibility I'd likely ever need but I'm a latecomer to the vacuum table business and a little bit unsure of myself at this point.
Anyone wanna put in their 2 cents? Brady? David? Ed? Anyone???
