Results 1 to 10 of 11
Thread: CAD Software
    Sep 2007
    Default CAD Software
    This is a question for the collective.... What 3D Modeling or CAD software are you guys using to create or manipulate DXF files?
    I need to bite the bullet and make a software change.
    TIA,
    Mark
    Dec 2006
    Accurate Graphics, Memphis TN
    We use Corel Draw v.12, but we have had better luck exporting our drawings as .EPS files, rather than .DXF, for importing into PartWorks.
    Sep 2007
    I too have CoralDraw, but when I import them, I have to draw open a box for the size. Then I end up having to size the part to be dimensionally correct. Before I import it I even set the drawing size to the size of panel I will be cutting and I still have to resize it. Is there a way that on the import it will drop in 1:1 SCALE?
    Thanks for reminding me..... I use it to pull in EPS files as well.
    Dec 2008
    Dec 2006
    When you create a new file in Corel, it defaults to a Page Size that is 8-1/2" wide x 11" tall. Change these values to match your intended Material Size (and orientation) in PartWorks.
    Create your drawing full-size in Corel and position it within the page. When you export the file, it will be accurately sized and positioned in PartWorks.
    Oct 2000
    Willis Wharf, VA
    Hey Mark,
    You might want to check out the free version of Alibre...Kirk and Connie Kelsey are doing a ShopBot web column on it.
    http://www.shopbottools.com/KelseyAlibre.htm
    I hope to get their next installment posted by the end of next week so keep checking back.
    Bill
    Jun 2007
    Hampton Roads, VA
    I use 3D Studio Max. http://www.resources.autodesk.com/med/Autodesk_3ds_Max
    it is admittedly a heavy price point for CNC only.
    Edit: Although given the price of Aspire, ArtCam, etc. Maybe it isn't.
    Aug 2004
    Cromer, Sydney NSW
    I use TurboCad V15
    export from TC as either EPS or DXF and import into either ArtCam or VCarve, toolpath and then cut.
    I am even able to draw 3D cabinets in TC and then use woodworker option to layout the cabinets into sheets export as dxf and then toolpath the sheets.
    David
    Sep 2007
    Thanks for the input....... I will check these out.
    Mar 2001
    Somerset, UK
    Rhino with RhinoCam. Love it, but bear in mind that the best choice for you depends on what you'r egoing to be cutting.
  1. Software for Mac?
    By jdwykrent in forum ShopBotter Message Board
    Last Post: 01-27-2015, 12:46 PM
  2. software to cut vac top?
    By SPARROW in forum Folder 2011
    Last Post: 01-30-2011, 09:38 PM
  3. Software, Software, Software
    By nick in forum Archives2007
    Last Post: 12-31-2007, 06:54 AM
  4. What software do you use?
    By kivimagi in forum Archives 2004
    Last Post: 07-14-2004, 08:50 AM
  5. Replies: 36
    Last Post: 04-10-2003, 09:49 AM
