Hi All.
Nine months of writing proprietary CAD software and setting up a shop from scratch and my Custom Closet business is almost ready for full operation.
I have no experience in woodworking as a business. I have a background in manufacturing and have come at it from that angle. Many of my non standard ideas have paned out and some have not.(The tech installing my edgebander shakes his head and says: I ain't never seen a cabinet shop that doesn't have a table saw!) I am hoping this is an advantage but, do not want to reinvent the wheel either.
After some tweaking the shopbot is going to be able to do exactly what I need out of it. I have installed a 2nd Z with a 3 drill aggregate for 32mm systems holes. I am in the process of installing an air drill and raising the table about 3 to 4 inches. This should decrease the Z flex I am getting by pushing the machine a bit hard. I can now cut 3/4 Melamine accurately with 2 passes and after raising the table I expect to cut large pieces at 8ips in one pass.
My goal is to process at least 5 sheets per hour from the Shopbot to the trailer, ready for install. This includes all setup and clean up. I am currently achieving 3 and see 5 as a reasonable goal.
After producing my first couple of jobs I have identified some areas that could clearly stand some improvement.
I can use all the help I can get on these issues!
1. Labeling parts is taking quite a bit of time and is a place for errors.
Right now I print labels and use a layout sheet from Cabinet Parts Pro as a map for labeling.
I am using CCP for my Nesting before import to my software. (To keep production up, I am now applying the labels while the machine is still cutting the last pieces. I cringe at the thought of a shop employee doing this!)
QUESTION: Is there a device that can be mounted on a CNC that prints and applies labels?
2. Cleaning. While the top of the panels are clean after running a sheet there are lots of chips left in the kerf(comprssion bit). I am thinking of putting a trough at the end of the table attached to the DC so I can collect the mess at the time of parts removal.
3. Cleaning Part 2: I have a clean up routine that cleans the spoil board but, with the existing dust skirt it takes too long. I think with some mods to the dust skirt and routine I can cut this time in half. ANY SUGESTIONS?
I feel it very inportant to keep dust under control so, blowing the table off while quick, is not an option for me,
4.Cleaning Part 3: Final Cleaning of panels. While the tops are relatively easy to clean the bottoms that were on the spoil board are a bit more time consuming due to finer particles and static. I am thinking of building a machine, basically a box with a static eliminator bar followed by a blower to speed this process. I am thinking of trying a Shop-Vac or Fein as a blower and self contained dust collector. ANY SUGESTIONS?
Thanks for reading this long post.
Happy Holidays to all!
