I'm trying to run a .sbp file that was created by a fellow shopbotter in Artcam Pro. When I try to run it, it crams all the lines of code on one line with each original line seperated by a box (symbol). I can go into editor and put in a blank line after each line of code and it works fine. Not bad on the file with 350 lines but the 20k line file is a little much. The file runs fine on Frank's (Shopbot) machine. It does the same thing on both computers I have setup with control software. Other files I have created work fine on both my machines.
