Hi gang,
My first ShopBot question is about fretboard slitting.
A fretboard is the part on a guitar neck that the frets (wires up and down the neck) are attached to.
The slit that a fret wire is hammered in to is abou .020" wide. It is a simple kerf with a flat bottom.
They are spaced at decreasing intervals along the fretboard which typicaly measures about 18" long.
I am imagining I will need to make a dedicated spindle that mounts horizontaly on the Z axis.
but then I remembered I often over complicate things, especially when I'm unsure.
So I put it to you folks,
Is there a simple way to make these fine slits?
Are bits this fine redily available?
I've attached a picture of a typical fretboard.
common materials are: Rock Maple, Indian Rosewood and Macasar Ebony.
