Wow Gary,
I hope you are as jazzed with your work as the rest of us?
I have a few questions I hope you have time to answer:
1. It appears you have a conventional Bot sculpting 2" foam.
Did you provide registration marks or any kind of alignment cones on the back side before doing the carving? Or do the carvings simply lines up well enough layer after layer?
2. Would the 12" gantry riser ShopBot offers for foam been advantageous despite your outstanding results?
3.Do you know...or anybody else: Is the gantry riser interchangeable with the normal gantry? If so...is the process a day job, 6 hours, 30 minutes???
Specifically, if a guy had a 48 buddy and wanted to do foam for a month or so....would the 12" gantry riser be worthwhile or is slicing files the thickness of available foam totally suitable?
TIA
