Results 1 to 5 of 5
Thread: Vcarve Bamboo
    Jun 2007
    Bedford Hills NY 10507
    Default Vcarve Bamboo
    I'm V carving some bamboo cutting boards.
    Any suggestions or concerns
    Thanks in advance
    Erminio
    Apr 2007
    Marquette, MI
    Erminio...
    Sharp bits... keep em moving! For profile we have better luck with O flutes than Compression or end mill. Watch the grain change as chipping will happen.
    Gary
    Jun 2007
    Thanks Gary
    That's what I thought,just wanted to confirm
    Erminio
    cnc routing, portland or
    cutting to shape a downcut bit works great I just cut 5 sheets. but if you want a smooth cut it is best to do a cleanup pass. bamboo tends to not cut smoothly.
    the ply can warp too when vcarving if you remove much surface material.
    Jun 2007
    Thanks for the additional advice,Steve.
    I'll be cutting some today.
    Erminio
  1. Bamboo Plywood
    By Justin G in forum Product/Supplier List and Requests
    Last Post: 01-20-2016, 06:14 PM
  2. cutting bamboo
    By twelchPTM in forum Techniques for Cutting, Drilling, Machining
    Last Post: 06-13-2015, 12:24 AM
  3. cutting bamboo ply
    By 2006prt in forum ShopBotter Message Board
    Last Post: 11-17-2014, 02:47 PM
  4. Bamboo bowl
    By shoeshine in forum Folder 2013
    Last Post: 08-05-2014, 12:18 PM
  5. BAMBOO
    By coach in forum Techniques for Cutting, Drilling, Machining
    Last Post: 04-08-2009, 07:47 AM
