Hello Shopbotters:
I cut my first vacuum plenum board (4x8) from MDF Saturday, and sealed it with a waterproofing sealer for wood/masonry. I was very disappointed with the result - it seemed that the MDF soaked up enormous quantities of the thin liquid and swelled up...
In retrospect I think maybe I should have used a urethane sanding sealer type product? But, after this experience...
Is it really sensible to use MDF? Is there some type of plastic or PVC material that would be air tight, require no sealing, and be more rigid than MDF? Gary Campbell you did something like this, right?
I would rather abandon the MDF and do something else now if that is what needs to be done to make a reasonably permanent plenum board. But, if I just used faulty technique, I'm open to advice.
Gerald
