Ok I am making a case with hidden hinges about 11.75 x 9.75 x 1 each half. I drew this in Aspire. I then went to my toolpath . I picked the cutter, feed rate, set path depth, spindle speed and filled in all the other inputs. I did the calculate and run the preview toolpath. All looked great, so I saved toolpath, picked the post processor ShopBot (arcs)(inch)(*.shp) .
Now I start my ShopBot software. Get my file 11.5 case and try it in preview mode. Then the problems start. It seems to cut the hinges out fine. But at closer look, instead of cutting it .25 deep, it all the way thru the board and the last hinge hole is way too close to the end of the case. So I check the box size in the shopbot material preview. I find that instead of the case being 11.75 x 9.75 x 1 it 8.65 x 4.75 x .22 ( for every tool path that I save the case comes out to have a difference board size. Also when I start to cut out the hinges in cut mode,the cutting start about two inches from where it should of and ramps into the hinge starting point. Then drills almost thru the 1” board.
Can anyone help with this. Oh I have a prsalpha. I have reinstall the firmware and running 3.6.14
Thank you
frank
