I have a question with regards to the spoilboard and attaching it to the vacuum plenum board/surface. In my previous configuration I used a rubber seal around the perimeter of the zone. That worked OK as I only had four zones. However I didn't always end up with a flat surface. Since I have reconfigured everything, I wanted something a little more reliable and semi-permanent. I now have eight zones with t-track in between. I dont want to glue the spoilboard down to the vacuum board because if I have to change out one of the eight zones, it would really be hard to maintain consistancy. What I was thinking about was using 2 inch carpet tape to attach the spoilboard to the vacuum board.
My question..... Has anyone done this and were they successful in maintain vacuum through the zone with minimal loss. Also I just happened to think. Since I sealed my Vacuum board could I use a small bead of 100% silicon adhesive to attach the spoil board. I am only looking at attaching the eight individual spoilboards around each of their perimeters.
If this has been dicussed before I apoligize. I looked for a reference, but my search came up empty.
TIA,
Mark
