So lately I've been doing a lot of pink foam (foamular) carving lately. The nice thing about pink foam is that it pretty much the easiest thing in the world to carve. There's almost no resistance to the cutter, I can hog through it at 4 inches per second with no problems. But I'm wondering if I should have a different set of ramping values for when I cut this type of material.
My understanding of the ramping values is that they affect the acceleration of the tool, and that this is limited for a couple of reasons:
- To account for the momentum of the tool, and thus prevent visible "chatter" from when the bot changes directions too rapidly.
- To prevent cutter deflection when working in hard materials
The question is this: Is my understanding of ramping values correct and complete? And does it make sense to use different values when cutting a light weight material like foam.
The endgame of all this is to make the cuts faster. On this kind of work loosing a little bit of accuracy is okay, since we tend to sand before painting anyways.
Thanks!
-D
