Results 1 to 8 of 8
Thread: Upgrades?
    May 2006
    Ontario Canada
    Default Upgrades?
    Is there any large changes in sb3 software upgrades? I am still using the version that came with the machine last October (3.5.3 I think). I realize to keep up to date but are there any real large performance or control advantages in the updates.
    Thanks in advance,
    Glen
    cnc routing, portland or
    I think thats the newest version. I have 3.4 and noticed no real difference going to 3.5 well I had problems with 3.5 and have gone back. some new features between them but the machine runs the same from what I could tell.
    Jan 2007
    Pennsylvania & Florida
    Good question, I wondered the same. "If it aint broke..."
    RECENT VERSION RELEASE NOTES (Full History in Readme File in software)
    Version 3.5.5
    -Updated native G-code reader and G-code Converter (old converter installed as: UX-GCODE_previous.EXE)
    -Automated ShopBot identification and port finding routines.
    -Support for new Version 201 ShopBot Controller Card. Drivers may be installed during software install. Also available under C:\Program Files\ShopBot\ShopBot 3\Drivers.
    VERSION 3.5.4
    -Zeroing routines modified to set Table Base Coordinates automatically.
    -New Version "Copy Machine" Tool. Should be faster and more robust.
    -New Version "Surfacer" Tool.
    -New Spindle RPM Control Tool (for optional VFD Spindle Speed Controller; available soon from ShopBot).
    -Zeroing routine will now optionally zero 4th (A) axis if present.
    -New buttons to "Edit Current File"; "Re-run Current File".
    -New feature in [VU] adds capability for extremely slow speeds (see Command Reference).
    -New parameter in [VR] allows adjusting ramp rate in KeyPad for ShopBotters who want to accelerate faster (see Command Reference).
    -New parameter in [VD] allows setting KeyPad closure to automatically turn off outputs (see Command Reference).
    -New Settings file folder structure. Should be easier to use.
    -New system available under Help for a customer to ZIP and send diagnostic files to ShopBot Support.
    -The automatic "Find ShopBot" should get the right connection on most computers.
    -New "Speed Test" utility that is more accurate in determining communication speed.
    -Buffer-Underflow (communications chokes) now reported in Problem.log.
    -New firmware reports outboard serial numbers.
    -Several small bugs in G-code reading fixed.
    -Reads Unix/Linux/Mac file types (previously a problem with carriage-return/line-feed).
    -Software smoothing for arcs upgrade.
    VERSION 3.5.3
    -Fixes 3D bug (seen in some V-carving and sometimes in stops in 3D files)
    -Fixes occasional issue with long shallow diagonal
    VERSION 3.5.2
    -Updates the Setup Virtual Tool for PRS's
    VERSION 3.5.1 vs 3.4.x
    -Smoother diagonals, arcs, and circles [NEW SMOOTHING STRATEGY]
    -Supports higher step rates (thus allows higher speeds with hi-resolution gearing or microstepping)
    -Supports PRSstandard and PRSalpha Tools (including Normally-Closed Proximity Switches; New Parameters in [VN] and New XYzero program installed)
    -Supports PRTstandard Version4 Boards (with Geckodrives) and later
    -Configurable/remembered Window sizing (allows better control and useful variations of screen layout)
    -New [MD] Command for moving a designated Distance and Direction
    -New [SI] Command provide a scratch pad for direct entry of several commands.
    -Simultaneous G-code or ShopBot Code in files (supports same commands as G-code converter; added functionality for follow)
    -More responsive keypad (asymetric ramping for more control; slow up-ramp, fast Stop; threshold for fast Stop in [VR])
    -Can now call various Zeroing Commands from KeyPad mode (requires an ENTER to confirm)
    -In KeyPad mode, when using 'Fixed Distance' to go a defined short distance a direct window for changing the distance is now available.
    -% Part File Completed readout added to status line
    -Added Extruder Virtual Tool and Utilities Virtual Tool
    -Allows faster probing/digitizing
    -Added feature to automatically identify ShopBot Port connection
    -Diagnostic tool for testing the efficiency/bandwith of USB connection (see [UT;SpeedTest])
    -Updated PartWizard Posts automatically installed (if PW folder not found, installed to C:\SbParts\PartWizardPosts)
    -Supports alpha & V4g Torch Height
    -Updated Typesetter, Fluter, Surfacer, and Indexer Virtual Tools to include SO commands to turn router or spindle on and off
    -New Programming Command in Part File Language: MESSAGEBOX (see new Programming Handbook installed to C:\Program Files\ShopBot\ShopBot 3\Help\ProgHand.pdf)
    -Enhanced Programming Command in Part File Language: SHELL now includes both ASYNC and SYNC start options (see new Programming Handbook)
    -Virtual Tool calls from software now support passing command line as parameter (see Programming Handbook)
    -Update to vb6 example files in Developer tools folder
    -User Variable Max Number to 1000
    You can access the latest SB3 version history via: http://www.shopbottools.com/SBCSupdatenotes.htm
    May 2006
    Baton Rouge, LA
    I always try to keep my SB3 software up to date. In some applications I have to set the Z plunge rate to the minimum .05"/sec. I have found a problem in both 3.5.4 and 3.5.5 trying to use this plunge rate. I had to fall back to 3.5.3 to get reliable results. SB is aware of the problem and hopefully will be fixed in the next release. There is a lot of improvements in latest versions and I think it pays to keep up with the latest revs.
    Oct 2005
    Olympia, Washington
    Any idea what the new 201 ShopBot Controller Card does over the older version?
    As I understand it, it's a bit faster and has some behind the scenes stuff that will open up some more features in the future. You're not missing anything, if that's what you are thinking.
    Jun 2005
    Portland, Oregon
    I am curious what other future features might be there...I was told they were just replacing the 3rd party serial to usb converter with a custom component.
    -Howie
  1. Potential upgrades
    By sawkerf in forum ShopBotter Message Board
    Last Post: 10-10-2013, 05:52 PM
  2. Worthy upgrades
    Last Post: 10-03-2013, 10:09 PM
  3. PRT Upgrades
    By jdgrahamwaldorf in forum Variations & Modifications of ShopBots
    Last Post: 09-21-2009, 09:28 AM
  4. Upgrades
    By f0bic in forum Archives2007
    Last Post: 11-12-2007, 09:38 PM
  5. Upgrades?
    By smk in forum Archives2006
    Last Post: 10-21-2006, 11:48 AM
