This morning I had to change a blade on my table saw and some how set a level down beside the Shopbot. After changing the blade, I went over to the Shopbot to move the carriage down so I could remove the blank from my last project. Didn't notice the level, it caught in the motor and pretty much jammed the level through the back of my control box that is mounted under the table on that side. I quickly shut everything down, removed the level, and took out the control box. Several of the component we bent over but as far as I could tell nothing was broke off the board. The only thing I knew was broke was the ground mounted to the back wall of the box. I fixed that, cleaned everything up and tried powering everything back up. Everything looked good but when I try to make the Bot move the motors just click. The numbers are scrolling on the control software but nothing is actually moving. Not in X or Y.
Normally I would just take this as a sign I needed to take the holiday weekend off and drive the box up to Shopbot on Tuesday but I have a project to finish that has to be delivered for a memorial.
Is there anything else I can check to see if she'll run again without professional help from the Shopbot repair guru?
Thanks in advance even if the answer is not what I want to hear.
