Results 1 to 7 of 7
Thread: Tool Path
    Jun 2004
    Fuquay Varina, NC
    Default Tool Path
    I made a tool path using Vcarve Pro, when I run it on my PRS it seems as though every thing is backwards. The Y is reversed and the X is also. I've dried remaking the tool path on 2 computers, with the same results. I reinstall the Shopbot software, same thing happens. I need help!!! This little job has got to be ready in the morning.
    Thanks for your help
    Jimmy
    May 2004
    Albuquerque, NM
    Not sure but sounds like you have your V Carve set up with x and y in opposite direction/orientation from your machine. I'm Not in front of V carve at the moment but suggest you check orientation in art/program and see if they are reversed in settings.
    Jun 2004
    Fuquay Varina, NC
    I've run it on 2 computers, here is the Vcarve file.
    Jimmy
    main.rar (12.9 k)
    Does your machine travel normally with the (K)eypad?
    The only thing I see in your file is that you have chosen "Climb" cut instead of "Conventional".
    You don't have a negative proportion in the fill-in sheet do you?
    Jun 2004
    Fuquay Varina, NC
    Key Pad works fine. Fill in Sheet?
    Jimmy
    , Morehead City NC
    Does the preview in V-Carve produce the expected result? Are you sure you have the correct post processor selected? If both of these are OK, then I would e-mail Vectric support directly. Tony and his staff are very good about solving problems in a very timely fashion, even on weekends. If it turns out that it is not a Vectric issue, then I would call ShopBot tech support. They too, are very good about problem solving, even on weekends. I'll be interested to know what the final solution is.
    -Matt
    Jun 2004
    Fuquay Varina, NC
    I reinstalled the SB software again and now it is running right. I don't know what was wrong.
    Jimmy
  1. 3D tool path
    By angelosart in forum Techniques for Cutting, Drilling, Machining
    Last Post: 12-13-2013, 08:57 AM
  2. Tool path question
    By wendell in forum ShopBotter Message Board
    Last Post: 11-07-2012, 10:30 PM
  3. Tool Path
    By matney_models in forum ShopBotter Message Board
    Last Post: 06-14-2010, 11:29 PM
  4. Need help with 3d tool path
    By john_how in forum PartWorks
    Last Post: 02-12-2010, 04:39 PM
  5. 3D tool path
    By don in forum Other
    Last Post: 12-16-2008, 01:23 AM
