As is always stated, this forum is incredible and I need to ask for some input. Our machine is like the “little engine that could.” We just never got out of the blocks with it. And, I am trying to make the decision to start over with it or sell it to a deserving home.
Basically, we have a 3 or 4 year old well outfitted 5x10 Alpha PRT(?) with dual “Z’s”, two VFD spindles (one Colombo, one HSD), an air drill, 15hp vac pump. We have Kcdw and Artcam Insignia. The spindles have NEVER been used with out warm up and cool down cycles. Generally, this takes longer than running the file we are going to cut. If this machine has run 80 hours since new, I’d be surprised. We are on our second spoil board if that is any indication. We only use it for the occasional curved piece of counter top or whatever. I should mention, we build commercial cabinets almost exclusively.
The plan was to have a semi-retired machinist/CNC teacher friend build and run it to make cabinet parts. He built it (to very tight tolerances I might add), and then moved away when his daughter gave him a grandchild. I understand. Since then, I have been trying to learn how to make this machine “sing.” But as someone said in a previous post, it’s like a shuttle launch to cut a part compared to other machines in our shop (blessing and a curse). The way it was assembled with 5 zone valves on one end, the computer on the other side, the control for the vacuum panel lift (Oh yeah, I forgot, we have one of those too) on the opposite end, the dust collector behind the machine, material loading on one end and off loading the other, controls for the vac pump on the wall, the VFD’s under the machine, it’s a pain to make anything efficiently. Plus I am stuck spending too much time cleaning the table. When he built the machine, my friend was used to thinking in metal working terms. Slow but very accurate. He just wasn’t thinking like a woodworker.
My employees do not want to learn this machine. I am busy trying to run the business. I feel overwhelmed at the prospect of stripping it down, re-plumbing the vac system, new plenum with more effective zones (for our sheet good sizes), implementing electro/pneumatic valves, inventing a pop-up pin locating system, etc. Also dumping the Insignia/Cabinetmaker software, which is horrible for my business, and starting over. If I can’t force fit it to become as user friendly as our old point to point they’ll never use it. Right now it’s SO MUCH MORE efficient to cut on one of the panel saws and go down the line.
So what it comes down to is if it’s worth spending all that additional money and time to get it to where someone besides me could run it (efficiently) or what this machine might be worth in the right hands (considering the money spent on it). Then maybe someday buy a machine that has all the convenience features built-in from the manufacturer. “Arguments” on both sides of the aisle are appreciated.
