I finally have everything together wired, ready to go. I shut the power supply door and switch won't turn to the on position. I'm afraid to use too much force but in jiggling it the inside white nylon fitting falls out. I can't turn the machine on and close door because door won't seat properly. Is there a exploded view of this switch anywhere so i can try to put it together? Can i run the bot by turning the switch inside to the on position and shutting door? It seems like the switch won't allow me to do that?
