I'm not sure if a buddy is made like a alpha with the big control box however I ran my tool into a block of wood cutting and I couldn't get it stopped before it blew the fuses. They are solid (buss?) type fuses, that to look at them you would not know they are blown. I replaced both of mine at around $10.00 each but i was having some of the same issues where you had power but nothing moved. Mikes post reminded me of it. Pull the fuses and check them. You may not have done anything to cause them to blow they could have just been weak. Use a plastic fusepuller or make sure its disconnected from the power.
