Does anyone have a source for a 1/8 inch bit (1/4 collet) with the length to cut through 3/4.
Todd
Todd
not sure if it is the cheapest but Grizzly sells a couple types
www.grizzly.com
search spiral bits...
Gene Crain
www.plantasymaderas.com
centurion has one as well .. look in the straight flutes..
mitch
centurions bit is around only .5 inch in cutter height. I needed a .75 cutter length and called, theirs wasn't long enough.
Mitch is correct, Centurion has one.
http://www.centuriontools.com/router...=5&id3=430
Thank you all for the information. Can I get away with cutting 3/4 maple at 1 ips in 3, 1/4 passes? I am not sure how fragile these are. I an cutting some fine detail stuff
Best,
Todd
Todd
Do your roughing pass to remove as much material as possible. Then follow up with your 1/8 bit. There not cheap
IS THIS WHAT YOUR LOOKING FOR AT CENTURION.
SKU: 18SF2.752.5RES14Product: 1/8" DIAMETER 3/4" CUT LENGTH 1/4" SHANKQuantity: 2Price: 20.70Total: 41.40
"Can I get away with cutting 3/4 maple at 1 ips in 3, 1/4 passes? I am not sure how fragile these are. I an cutting some fine detail stuff"
Todd,
The short answer is no. I have used that exact bit to do some area clears in soft maple(.2 deep @ 1"/sec) and snapped them right off. Take a lighter pass, as it gets mighty expensive to spend $20.70 for 2 inches of cut.
I don't think it is a centurion issue, it is just a lot leverage on the bit, and the way it is made doesn't leave much meat where it transitions down from .25" to .125".
centurion is coming out with a 1/8 O-flute with a 3/4 cut length..... they just decided that in the last day or so..
m
