I am designing a plate for the church using a side view. I plan to then convert those coordinates from NC X,Y -> X,Z and use the CC command to cut the circular plate so that I do not need a spindle to cut a plate.
The only problem is that the Shopbot code produces CG commands ... Is there a way to force it to produce m3, x,y,z instead of CG commands?
