I just fired up my PRSalpha BT32 (router) for the first time. As per user guide, it initially asked for the proper setting file for my unit for the Shopbot.ini. There was only one benchtop in the list, so I chose that one. All looked OK, so first thing I did was hit the K and started manually moving my axis around with the keypad. Problem is, in all axis, for every inch the software screen says it moves, it only actually physically moves ½ inch. I am assuming there is a simple setting I need to tweak to correct this?
