Let's Talk ShopBot
Go Back   Let's Talk ShopBot > ShopBot Specific > PRS Assembly > Spindle and Router Mounting
Reply
Thread Tools Display Modes
  #1
Old 04-29-2011, 06:48 PM
Anthony Welch Kemosabe62 is offline
New Member
Default Need help w/spindle.
Recently purchased a PRS 96x48 2007-2008 model shopbot w/spindle. I was told it was a single phase 5hp. Guy had it wired direct to breaker box.
Anyway machine is up and running correctly. But can't get spindle to run. What I have is a Yaskawa v74x controller, spindle is model HSD- AT/MT 1073-140. shopbot controller is the type that looks like a computer. The only wire from the SB controller is to the spindle fan and is running it fine. No other contacts from SB controller to spindle is present. Orange cable is connected to spindle. Large black cable from vfd has 3 wires black, red and green. red and black are run to a 50 amp double pole breaker and green is run to ground.
I'm in need of some serious hand holding here. As you may can tell I can't read wiring diagrams. Pictures are better for me to understand. I feel I may be under powered, as is the reason I gave model #'s.
Shop is wired 100 Amp?.
I would like to get this going this weekend or the wife says I'm sleeping with it. She don't know but when it gets going, we'll be together, me and the SB the whole weekend.
Anthony
  #2
Old 05-02-2011, 09:13 PM
mtylerfl's Avatar
Michael Tyler mtylerfl is offline
Senior Member
Hi Anthony,
Check that your 220 feed is connected to terminals 1 and 3 in your control box...I originally had mine on terminals 1 and 2 ... the fan was running (from 110) but the spindle would not run because it wasn't getting power...the wiring diagram clearly showed that 220 was supposed be connected to 1 and 3, but my electrician missed that! A quick call to ShopBot Tech Support revealed the error of my ways. Reconnected the 220 (properly) and I was up and running in about two minutes!
NOTE: the machine I use is the PRSalphaBT48 so I don't know if your wiring diagram is the same or not...you will need to peek at your diagram to verify the terminal hook-up...you may want to call Tech Support and let them help you to be on the safe side
  #3
Old 05-02-2011, 10:14 PM
New Member
Thanks Michael I'll give it a look see tomorrow.
Anthony
  #4
Old 05-03-2011, 11:58 AM
New Member
That is all connected properly.
  #5
Old 05-05-2011, 08:15 AM
mtylerfl's Avatar
Senior Member
Hi Anthony,
Were you able to get things going yet? (It's almost the weekend!)
Call the fine folks at ShopBot if you're still having trouble...they are always there for us!
  #6
Old 05-05-2011, 09:02 AM
Mike SomeSailor is offline
Member
Can you put the VFD in local control using the LO/RE button? You can start the spindle there afterward, so be careful.
  #7
Old 05-06-2011, 08:12 PM
New Member
Found out that not all double pole breakers are the same. Got the one I actually need and it works fine. Now I've got a ton of scraps to practice on.
Anthony
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2012 ShopBot® Tools, Inc.
