Let's Talk ShopBot
Go Back   Let's Talk ShopBot > Applications and Techniques > ShopBot in Schools
Reply
Thread Tools Display Modes
  #11
Old 09-16-2011, 05:11 PM
bleeth's Avatar
Dave Rosenbleeth bleeth is offline
Senior Member
Oh Darn! I was really curious about what kind of showboat one would run up around Lancaster
(Just a joke from an old Philadelphian!!)
  #12
Old 09-16-2011, 07:02 PM
gc3's Avatar
Gene Crain gc3 is offline
Senior Member
http://www.discount-tools.com/webspecials1.htm
http://www.discount-tools.com/endmills1.htm
USA made work very well for the price...
__________________
Servicio de Fresadora CNC
Vector Studio 22
Los Cabos, Mexico
  #13
Old 09-17-2011, 09:25 PM
Edward Harrall hh_woodworking is offline
Senior Member
Make sure that your students do an air cut of the file first. This will save a lot of money in bits. I know from experience with students.
  #14
Old 12-09-2011, 09:34 PM
Thomas Peters Tom Peters is offline
New Member
Default Reasonable Bits
I have been using and teaching CNC Routing with a Shopbot PRS 9648 in a Community College and I also use several home built machines and have bought bits from several companies. For most 1/4 inch and 1/8 inch spiral bits and 1/16 ball ends for 3d I use American Carbide. They are great and sell a good product at a reasonable price. I also purchase from Infinity, Bits and Bits (mostly 1/8 inch ingraving bits and other specialty bits. We do a lot of 3d and a lot of VCarving. The 60 degree laser point from Infinity ($29) is the best VCarving bit I have ever used and they last forever, if you don't drop them on concrete). I am still using one I purchased three years ago, although I just purchased six more for myself and friends. They are very popular around here. We use 1/4 inch and 1/8 inch down spirals the most for roughing 3d and for profile cutting out signs when finished. I hope this helps.
  #15
Old 01-19-2012, 07:47 AM
Roy Harding Roy Harding is online now
New Member
Default False Top For Desktop
Quote:
Originally Posted by Jacobsonr View Post
Thanks guys, that's great. Only 2 so far and two big gouges in the table of my new showboat desktop :0(
I know the 4x8 machines are bit different, does anyone have suggestions on a false top for desktop model.
I realize this question is a few months old - but as nobody else has answered, I thought I'd tell you what I did.
I mounted a 28 1/2" X 24" piece of 1/2" plywood to the aluminum bed of the Desktop. I used countersunk machine screws, which screwed into the mounting brackets which came with my Desktop (the brackets are oval shaped pieces of metal with a threaded hole in them - they are made to slide in the tracks of the aluminum bed).
I then zeroed the X/Y axis using the proximity switches (C3 Command), and used the Shopbot to carve a 1/8" deep pocket 24" X 18" (the max carving area of the Desktop) into the plywood. Then I used contact cement to install a 24 X 18 piece of 1/2" MDF into the pocket. This enabled me to screw two fences to the plywood, to the left and bottom of the MDF sheet. By using these fences to position my workpiece, the bottom left corner is consistently located at X/Y Zero.
Whenever the MDF becomes too chewed up to use, I flatten it until all imperfections are gone, then contact cement another piece of MDF onto it - then I flatten the new sheet of MDF after the contact cement has dried. (I usually put a new sheet onto the bed as the last thing in a day, then flatten it first thing in the morning).
I do recall that getting the original 1/2" plywood onto slid onto the aluminum bed was a pain in the a$$ - but you only have to do it once.
This setup has served me well for almost a year now - I carve many small parts, using 23 gauge pins to hold the blanks to the MDF - never had a problem.
If the above is not clear - send me a PM and I'll send photos of my setup.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Copyright © 1999 - 2012 ShopBot® Tools, Inc.
