I want to build a better solution to the standard bag and clamp system, but as things tend to go I am sure it will be a while before I get to it.
so in the meantime...any of you guys figured out a way to swap out bags without fighting aligning the clamp on the backside of the collector while your face is planted in the frontside? its so much fun when its full of mdf dust.
i finally realized that if you put a trash bag inside cloth bag it works pretty good - I use big rubber band to hold plastic bag, but still fight the cloth one.
I was thinking about some type of hook and grommet around the perimeter, but before I started anything I figured I'd tap into the cumulative wisdom of the forum.
