Our gently used bot will not operate. The guys at ShopBot say I need a dedicated neutral and a ground for proper communication. My home is a little older (1961) so my main panel has a single ground bus and no neutral.
After a little research (and yes, I do believe everything I read on the internet) I see that if a main panel has this configuration you can wire a subpanel and have an isolated neutral bus at the subpanel. I'm a little confused by this. What does this do for the circuit? It seems to me that having a neutral terminate like this would be useless.
Its time for me to get an electrician but I thought I'd see if anyone here could help me understand this question so when an electrician shows up I can explain to them what exactly it is I need and why. ShopBot techs did offer to talk to them if they have any questions tho. Those guys are great. Can't say that enough.
