Kinda a continuation of ...
http://www.talkshopbot.com/forum/show.cgi?tpc=33571&post=74265#POST74265
There are a lot of "home made" indexers floating around, but I'm always faced with the same problem...
How to keep a lathe chuck (SuperNova) tight on the drive axle when software wants to turn the material both clockwise and counter-clockwise. One direction will tighten the chuck, the other direction will try to loosen the chuck.
Sometimes just a slight "loosening" can ruin a project.
Set screws kinda work, but my indexer uses the 18:1 Geared PK296. In this picture the indexer is a Harbor Freight "lathe" without the motor with a Stepper Motor attached on the far left connected through a coupler. My chuck would go on the actual lathe spindle.
I'm thinking of mounting a chuck directly on the 1/2" stepper shaft... But how?
I could use the Teknatool SuperNov2 Blank Insert from woodcraft http://www.woodcraft.com/Product/200...nk-Insert.aspx
But the big question is how to keep the insert from rotating on the shaft AND keep the chuck from rotating on the insert.
What do you guys recommend?
-- Pat
