Machining a large radius. You should be able to do this with a .5" diameter cutter that is 2.5" long.
Desired radius, 3".
Along the edge with a ball mill:
Across the edge with a flat mill:
Steve - do you have RhinoCAM Pro? I only have standard....and as a practice session - I also was playing around with this both in Rhino & RhinoCAM.
Tom
Steve, interesting way to do that with and with an endmill bit as well.
I will keep it in mind if the job comes my way.
