Here's a case where the owner has jumped the gun and is not thinking it through.
The concrete and brick work has been done before we had a chance to get proper mounting brackets made.
Now I'm faced with mounting this sign to this concrete and brick structure.
I'm thinking that 2x4 angle iron (painted) bolted to the concrete and a slot cut into the sign and through bolted should do it.
Is this a good way to mount a sign?
Also the black outer area is wider than the lighter area with the letters.(3.5" for black outer area and 2' for recessed area.)
Is it easiest to glue up one large blank and mill out the recessed area or make the two parts separate form each other.
The letters will be milled out of PVC
I guess I should ask what is the preferred method of attaching the pvc letters?
They are to be attached directly to the wood,so the options would be to recess the wood(around .25)or attach to the surface.
Thanks Brian
