Results 1 to 8 of 8
Thread: My first two layer acrylic
    Jun 2014
    Houghton Lake MI
    Default My first two layer acrylic
    Two layers 1/4" acrylic , did something different and
    used a 4 flute end mill , pop's
    Jeff King
    shopbot buddy BT-32
    P/C - 3.25 hp
    The things I make may be for others ,
    but how I make them is for me . T. Konovaloff
    Not my style
    But hope you can keep playing!!
    Jun 2014
    Eastvale, CA
    That came out great. How did you separate the LEDs?
    I've been trying acrylic using a diamond drag bit. It works great for drawing lines, but when I need to engrave a large area like you did it's not working very well. Could you post the parameters you used for cutting with the endmill?
    Jun 2014
    Houghton Lake MI
    Hey Steve , on this piece was the first time I used a end mill on acrylic .
    It was a 4 flute 1/8 " bit , 12,000rpm , 110 ipm
    .002 depth . Run router slower if possible . I would have
    done this with a diamond drag but machine time was to long
    so that's why this experiment . If you use your diamond bit for a
    pocket do it with a 45 ' degree cut path then run again with a 0' degree
    Cut path . Just time consuming this way . Jeff
    Jeff King
    shopbot buddy BT-32
    P/C - 3.25 hp
    Jun 2014
    Houghton Lake MI
    Steve for the led's in the base cut pockets with
    a .04 wall between the two pockets and a shade
    deeper than normal . Jeff
    Jeff King
    shopbot buddy BT-32
    P/C - 3.25 hp
    Jan 2015
    Fairbanks Alaska
    Thumbs up nice
    very nice, thanks for sharing, one more thing i'd like to try. may i ask where you got the acrylic?
    "I am always doing that which I cannot do so that I may learn to do it" paraphrased from Pablo Picaso
    Jun 2014
    Houghton Lake MI
    I get mine locally . I used to get it at estreetplastics.com they have great prices and shipping . And very good selection anything you need . pop's
    Jeff King
    shopbot buddy BT-32
    P/C - 3.25 hp
    Jun 2014
    Eastvale, CA
    Hey Jeff, would you mind looking at my attempt at engraving acrylic with a diamond drag bit? I posted it in the Desktop part of the forum as a problem. I would really appreciate your thoughts on this. I can't seem to get it right.
    Steve
  1. Splicing base layer
    By cnc_fabricator11 in forum Table
    Last Post: 02-01-2012, 04:11 PM
  2. removing layer
    By brian in forum ArtCAM
    Last Post: 01-12-2012, 11:22 PM
  3. Nesting and retaining layer information
    By gabepari in forum ShopBotter Message Board
    Last Post: 04-06-2009, 12:31 PM
  4. Multi-Layer PVC
    By matt_r in forum Archives2006
    Last Post: 10-20-2006, 03:31 PM
  5. Multi Layer Board?
    By BBoehle in forum Archives - thru 2002
    Last Post: 02-08-2002, 10:27 PM
