Hey Alex, I'll have to look into that PVC from HD for $75. Wonder if that is decking material and does it come in 4x8 sheets? I have not used any PVC products yet and am anxious to try it.
And thanks again RossMosh for your helpful comments. When I cut the large letters out with the CNC I wanted to put a nice chamfer on the top edges so started with a profile tool path using a 60 deg v-bit. This allowed me to keep sharp inside corners, at least on the surface of the letters. Then I switched to a .25 EM and did the profile cutout. Because of the chamfer on the front, I didn't bother with counterboring the tab locations on the back. The vector graphic file I used was shared between the cnc and laser and it was no problem to quickly cut some paper templates with the tab locations. For many applications the laser is so much faster than doing the manual tool change, Z-zero, and material hold down on the CNC. With tab locations marked it took no time at all with a .75 forstner bit in a drill press to cut clean eighth inch deep holes on the backs of the letters.
This one job does not make me a sign guy, yet. I wasn't really sure what direction this CNC was going to take my business. Before the ShopBot I did mostly conventional woodworking for a mostly military clientele at a local Army Base. Custom built ins, display cases, flag stands, chain of command boards, policy letter boards, conference room displays with wall lettering and large layered military crests, etc, mostly cut out with a laser. For thicker materials I used the laser to cut thin templates to use for pattern routing of thicker parts on a table router. I also did lots of recognition awards such as raster engraved plaques, and sword holders and such. I was hoping that the 3d capabilities of the ShopBot would be a boon to my business by allowing me to produce a better product. This hasn't proven to be the case because I realize that the machining times for most 3d projects will price me out of reach. I can do a stunningly beautiful crest but the 10+ hours of machining and handpainting demands a price point beyond what most can pay. In this market anyway. In the meantime, I'm having a blast designing projects and using this CNC. I am building my resume right now with samples of what I can do. Most people have no imagination and they need to see something in order to see how this technology can fill their own needs. I am hoping that this lobby sign will generate other business. This is a large company that outsources many contractors for commercial jobs. The lobby traffic should create some inquiries. Maybe my future is doing house address signage for new subdivisions. Or architectural millwork. Who knows.
George
